Require help(newbie Questions)
rimmer
8
Hi
I m using Windows XP Pro my stats are
lex BN790TM VIA KT266
AMD ATHLOON 2000XP SOKET A 266 FSB
128 MB DDR
40GIG
64MB GEFORCE 2 MX 400
here are my problems
eveytime I boot my PC from cold it freezes a couple minutes later. I reboot roughly 2-3 times and everything seems to be ok.
I have also encountered an error where i hit a blue screen saying some about "IRQ not less than something" (cant remember exactly) then it goes on to say memory dumping. After it restart windows say "serious error has been encoutered" I have also encountered restarts with no error messages when playing games.
can anyone give advice on how to solve this problem ?
I was thinking it maybe the temperature being too high can it cause those errors above? Currently CPU temp is 63C and System temp is 35C
thxs
63 degrees thats pretty hot dude, theres heaps of things it could be, but I would deffo lower the temp of the cpu, Ive got a XP2400 and it runs at 23 deg
Me and Seven of Nine, Ohhh Yeah
63c is kind of high. But, within specs, <A HREF="http://139.95.253.214/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=92,E=0000000000102938838,K=2492,Sxi=14,Case=obj(1224)" target="_new">according to AMD</A>.
You should also check your memory with <A HREF="http://www.memtest86.com/" target="_new">Memtest86</A> and see if your memory is OK.
Also, if possible, you should check your power supply to see if it's OK.
My Daddy used to tell me:
<b>It's better to keep your mouth shut and let people think you're stupid,
then it is to open your mouth and prove it.</b>
I never was good at taking advice!
