Question resolution output hz problem
Jan 8, 2023
I'm using the victus 15 laptop and connect to the benq xl2411 by a hdmi cable and the monitor only can display 120hz at resolution 1440x900 (yes i know hdmi can only output max 120hz on the benq ) but the 1920x1080 is only 60hz
the question is why 1960x1080 can only outputs 60hz and how can i fix it
I'm a bit confused about what you're asking. If the monitor doesn't support it, nothing's broken to fix. You would need to connect to the monitor a different way.
yeah i just found out the monitor only support 120hz with 720p through hdmi cable but not 1080p i didnt know it when i posted this
