Question rgb fans help
Feb 11, 2025
25
9
15
aorus b550 elite v2 mobo
ryzen 7 5700 cpu
wd black 2tbssd
crucial pro ddr4 ram
znqi rgb fans
nitro sapphire graphics card
znqi rgb fans
the pc case has rgb fans there is a female block with 3 holes in which goes to the mobo
and one female connector with 3 pins i think its to ad more fans i plugged the female to the board they light up when switched on but dont spin any ideas please
That white connector is only for the LEDs (that attach to the motherboard LED headers or to a LED/RGB controller). They are designed so that you can daisy chain multiple devices to a single header.
There should be another cable for power. Likely on the backside of the fans themselves in your first picture. Those should be attached directly to the motherboard fan headers or to a fan controller.
