[SOLVED] RGB not working with fans
Marcus584
Commendable
May 2, 2017
25
Hello,
So I am building a computer with an older motherboard so it doesn't have the RGB built in. I have the Thermaltake V200 case which comes with the controller below. I also bought these Deepcool RGB fans https://www.amazon.com/DEEPCOOL-RF1...epcool+5+in+1&qid=1564437723&s=gateway&sr=8-1 . I daisy chained the RGB cable for the 3 fans as it said and then plugged them into the 12V RGB header below and plugged that into the 12V RGB on the case controller. The fans work but not the RGB. I haven't booted all the way but should they come on as soon as it boots or do they need to install drivers? Or is it just hooked up wrong?
View: https://imgur.com/a/FdfH0Pv
