petercli Prominent Jul 5, 2020 24 1 515 Aug 16, 2021 #1 I have a compaq presario 6000 , connected to a rgb monitor . the Character mode of windows (dos) is ok, but graphics mode is unreadable. any tips? Thanks, Peter
Solution S S SamirD Aug 17, 2021 You probably have the resolution set higher than the monitor can handle. Try ega or vga.
S SamirD Judicious Jan 16, 2014 6,608 953 35,940 Aug 17, 2021 Solution #2 You probably have the resolution set higher than the monitor can handle. Try ega or vga. Upvote 0 Downvote Solution
