nkarasch
287
Firstly, I bought an open box Asus motherboard. It is the P5K-e. Since it was open box it did not come with the metal peice that fits on the case in the back...maybe its called an i/o panel? Where can I get one of these for my board?
How should I clean the plexiglass side window on my antec nine hundred?
For single gpu/single card performance the G92 GTS is my best bet right now correct? The performance increase in the GTX isnt worth the 50% higher cost. The GX2 isnt expected for quite some time and would require a psu bigger than my 650w antec, right?
My first pioneer IDE drive I bought didnt work with Vista, but it worked with XP fine. The one I stole from my dad is an 8x drive than whines like a jet engine. Can anyone recommend me a drive <$40 that is quiet and fast that will work with Vista? Doesnt need to be fancy.
Thanks a lot
