Here all the infomation that i can think:
Did the stick not somehow turn inside the base of the analog control?
it seems it made a 90 degree turn counter clockwise........ try turning it back.
If you cant turn it back... can find a screwdriver and open it up, and investigate from there maybe you can see the fault / loose wire / problem...gl
I've already tried to open it and see if there was something wrong, but nothing. Tried to clean it from eventual internal dust that may have ruined the connection, double check all the wires and the analog itself. Everythings normal.
And what does the other remotes on the internet you found say that has similar problems.We need more info as its broken ...can you fix it....
http://www.techenclave.com/gaming/inverted-z-rz-axes-gamepad-128298/
http://www.gamefaqs.com/boards/950908-the-last-remnant/48719644 (here he changes the commands in the options ingame, but i can't do this with all the games)
The next 3 suggest to change the file option of the specific game, but it doesn't solve the real problem
http://board.zuxxez.com/showthread.php?33131-PC-Version-Gamepad-problem
http://frozenbyte.com/board/viewtopic.php?f=16&t=3867
http://www.bay12forums.com/smf/index.php?topic=94204.0
Well then it is not a Original control, considering you are using it on the computer and Playstation.....
I have seen MANY fake/cheap controls and sometimes they just break or malfunction all of a sudden.
I dont even know what make or model it is,?
How old is it - do you have sentimental value towards it?
Is it wireless or wired ?
If wired -- is the cable not damaged ?
i used 3 types: an original psone controller, an original ps2 controller and one of those third party controller.
the psone controller is old but it works perfectly when i plugged in the playstation, same thingwith the other two.
all of them are wired and the cable is in perfect condition.
I thought that maybe the problem was the adapter (this:
http://www.r-digital.it/images/Cavi_multiprese_adattatori/adattatore_ps2-ps3.jpg ) so i bought another one (this:
http://ecx.images-amazon.com/images/I/31XVp2yjKIL._SL500_AA300_.jpg ). But, again, nothing.
When i'm calibrating the Z axle only works with up and down, the RZ works with left and right. Tried with all the controllers and both adapters.
Tell me what i have to write if i forgot something. Also sorry for my english, and thanks for trying to help me
