Archived from groups: microsoft.public.windowsxp.configuration_manage,microsoft.public.windowsxp.help_and_support (
More info?)
Howdy Trond,
You betcha! Keep having fun!
Hope this helps. Let us know.
Wes
In news:ups$nfK0EHA.3236@TK2MSFTNGP15.phx.gbl,
Trond Ruud <truud2@netscape.net> hunted and pecked:
> Hi Wes,
> You seem to be on to something, since after uninstalling an
> re-installing winzip I succeeded in doing a right-click select of zip
> files and drag them to a target folder (with the winzip menu
> displayed over the target), in 2 out of 3 attempts, and if I can keep
> up that rate of success, I'll consider the problem solved.
> Thanks!
> Trond
> In news message:%23FfHRpC0EHA.3076@TK2MSFTNGP10.phx.gbl,
> Wesley Vogel <123WVogel955@comcast.net> wrote this:
>> Trond,
>> I did misunderstand your original post.
>> Could WinZip be corrupt?
>> Could be something be funky in the registry because of that?
>> WinZip ClassID = {E0D79305-84BE-11CE-9641-444553540000}
>> There are a slew of registry entries for ...DragDropHandlers\WinZip
>> Have you unregistered zipfldr.dll & cabview.dll ?
>> Start | Run | Type: regsvr32 /u zipfldr.dll | OK
>> Start | Run | Type: regsvr32 /u cabview.dll | OK
>> Reboot.
>> Instead of wasting time checking registry entries, maybe uninstall
>> and reinstall WinZip?
>> In news:O6HdrrA0EHA.2316@TK2MSFTNGP15.phx.gbl,
>>> Sorry, I should have been more specific. The left-click 'select and
>>> drag' works fine.
>>> My problem is with zip files. I've usually right-click selected the
>>> .zip file and dragged it to the folder that I want to unzip it to.
>>> Previously, when I right-click selected and dragged a zip file over
>>> the target folder I got a Winzip menu prompting to unzip to that
>>> folder. If I drag the zip file to the folder with a left click
>>> select, the Winzip menu doesn't display and the zip file is moved
>>> into the folder instead, which is rarely what I intend to do, and
>>> the right-click select and drag doesn't work as before, like I
>>> described originally.
>>> Trond Ruud
>>> In news message:O0yYepzzEHA.3120@TK2MSFTNGP12.phx.gbl,
>>>> Use left click to Select.
>>>> select
>>>> [[To specify a block of data or text on screen by highlighting it
>>>> or otherwise marking it, with the intent of performing some
>>>> operation on it.]]
>>>> In news:u7SOv7xzEHA.1264@TK2MSFTNGP12.phx.gbl,
>>>>> Selecting a file/folder with the right mouse button, for dragging
>>>>> no longer works (in my XP-SP2) Rather than selecting the file or
>>>>> folder to be dragged, the right mouse button now always
>>>>> immediately opens the right-click menu, whereafter dragging the
>>>>> file or folder becomes impossible. Are there some XP tweakings I
>>>>> can do to restore the standard right-click "select and drag"
>>>>> function, (without turning off the right click menu feature,
>>>>> that's very handy
>>>>> too, and I'd hate to lose it)?
>>>>> Trond Ruud
