Question RTX 2080 RGB compatibility with iCue
marek_shields
57
5
18,545
Hello folks,
I am in the market for a RTX 2080 for my new rig that I have all set up with a Corsair commander, RGB fans and a few light strips. I also have one of the Corsair RGB keyboards to go with the setup. Does anyone know if there are RTX 2080s that have iCue support? I don't necessarily need a GPU with more RGB lights on it but it would be nice, when I did end up finding one that like, if it had RGB lights on it that it was compatible with iCue.
No support for the GPU. Try the manufacturer of the GPU for software to control IF the GPU has RGB. I have a Galax RTX 2080 TI HOF and I use the RTX extreme tuner plus software to control RGB on the GPU.
