My fan speed keeps changing up and down. I tried to catch it in a gif. https://gyazo.com/da133896259abb46e7cdc084876c1742 Also my FPS is 30% lower than usual.
What are your full PC specs ? Which Power supply do you have ? Is that Fan behavior in IDLE desktop mode, or while Gaming ?
Yea i thought that was weird too, i don't know why it has two entries. The boost Mhz is jumping between 500 and 8000. I have an extreme amp card.The base GPU clock is 1515 MHz for most of the RTX 2080 Models, but the boost clock varies, depending on the exact GPU model. This database has all the cards listed with specs:
https://www.techpowerup.com/gpu-specs/geforce-rtx-2080.c3224
Your PSU is good. Have you tried doing a CLEAN re-install of the GPU drivers ? Use the DDU tool. BTW, is that pic/gif from HWmonitor ? There are 2 GPU entries under the 'Fans' section though.
ON my RX 480 I only have one entry.
