Question RTX 3060 with 5700G Performing way below expectations.
Dec 13, 2024
4
Hello all ive had this PC for a while now and kind of just dealt with performance issues thinking it was normal its just a regular 3060, but more recently its been alot worse I feel (or im just noticing it more lol) but on many games ive played (I.E Friends Vs Friends, Kingdom Come 😀eliverance, Rust) even some older games I struggle to run smoothly its always staggering fps and it usually never goes over 100fps in any game I play. Those 3 games I mentioned I cant even get a smooth 30 on lowest settings. https://www.userbenchmark.com/UserRun/69247392 this is my benchmark not sure how much it could help if at all. I know its just a benchmark but any help would be appreciated. Also my CPU almost never goes over 15-20% when im playing games but my GPU says its using 100% of its power. Thanks for your time any help is appreciated. EDIT 1: I think I have a storage bottleneck, my storage is hitting 100% on more intensive games. Its an old HDD.
Your RAM is running at 2133Mhz you should turn on docp in the bios
Reactions: Boolin
Did you notice any stuttering or lagging during the testing?
Yes it definitely wasnt the smoothest. I think im running into a storage bottleneck EDIT: its not a storage bottleneck I just ugpgraded to a 2tb ssd and still no major performance impact. Another option im going to try is using display port instead of HDMI but seeing as I cant even get over 60fps in most games I dont really think its going to help unless my HDMI is just bad. Starting to think my 3060 is just a dud. Seen people with the same GPU and worse CPU score almost triple what I did in the benchmark on same settings.
