[SOLVED] RTX 3080ti & Antec Edge 750W
Hello!
I did a calculation with most of the components being there hypothetically, since you didn't give the rest of the system, and check out the results. I would advise you to use the same website and calculate again with your real system specs. Hope this helps!
Hypothetical calculation:
-https://outervision.com/b/lfv3dJ
Seasonic G-series under the hood. Good quality and worth to try with your new GPU. Connect the GPU with as much seperate cables as possible.
Interesting. I didn’t know it was that under the hood. I’ll fish out the connectors that came with the PSU and have a go with it. I see no reason it shouldn’t work but I suppose you never know.
It's very unlikely that this PSU would work but you can just try it, it's a fairly decent PSU, getting too old for comfort tho. If it doesn't work or if you otherwise want a new PSU anyway, look at these :
https://pcpartpicker.com/product/DK...fied-fully-modular-atx-power-supply-ph-p850gc
https://pcpartpicker.com/product/Vg...-fully-modular-atx-power-supply-cp-9020180-na
Reactions: jonnyguru
