System:
MB: Gigabyte Z390 UD 1.1
CPU: 9700K
GPU: RTX 4080FE
RAM: 2X16 DDR4 3200mhz
PSU: Corsair RM850x
Before this I was running an RTX 3080 Aorus Xtreme with some crashing issues, but overall it worked Today I installed the 4080 FE and immediately ran into issues,
The clock speed seems to be stuck at 825mhz when using HWMonitor. When looking at GPU-Z the clock and memory metrics are blank and the Bus Interface is showing I'm running PCIE 1.1, even after doing the load test. When I try to play games, I get extremely poor performance, between 10-25fps on normal settings.
I've done many DDU runs and installed at least 5 different Nvidia driver versions to no avail. I've also played with the BIOS settings a good bit. I've set the PEG link to Gen 3 to force it to use that. The card is plugged into the 1 16X 3.0 PCIE slot. When I switch back to the 3080, it seems to work fine. I'm stumped now.
Maybe it's a MB issue? I'm hesitant to spend money on another motherboard with out any kind of strong hunch, plus the 9th gen chipset motherboards bios aren't being updated anymore. I wonder if maybe the card isn't seating properly, but it seems to click into place, albeit a little wobbly in the slot.
If anyone has an ideas of things to try or potential issues, I would be very appreciative as this card is a crazy price and it's very frustrating that I can't get it to work. I've had some issues with the other card using this MB but not to this level. Thank you.
CPU: 9700K
GPU: RTX 4080FE
PSU: Corsair RM850x
