Question rubber pad under Nvme drive
No. You don't need a rubber pad.
You could buy an after market heatsink instead.
https://www.amazon.com/Thermalright...074&sprefix=m.2+heatsink,aps,154&sr=8-21&th=1
Reactions: CountMike
Okay, thanks. My NVMe drive does not seem to get very hot; I have never seen temperatures above 50°C. My concern was more about people saying that they can bend over time with a motherboard heatsink, so I was wondering if it can still happen without any heatsink on it.
If anything, adding a heat sink to an M.2 drive will stiffen it, because it's now attached to a rigid block of metal.
As for leaving a drive bare, while technically it could flex and bend due to thermal expansion, I'm pretty sure manufacturers accounted for that so the drive doesn't exceed mechanical tolerances unless the drive is literally on fire. At which point you have bigger concerns.
Reactions: Rui Neves
so the odds of bending are more or less the same of a Motherboard or GPU ?
