Running a G6-400 'headless'
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Hi,
I have just acquired a new PC (Dell, sorry - Gateway don't sell in the UK
anymore), and I'd like to confure my old G6-400 as a server running Linux.
I want to operate it 'headless', i.e. without monitor , keyboard or mouse.
As regards the monitor I can simply not connect one, but I think the PC will
not boot if it does not detect a keyboard/mouse.
Apparently some computers have an option in their BIOS setup for running
without a keyboard and mouse, but I can't see it in the G6 BIOS. Anyone know
if this is possible?
Regards, John
P.S. I would actually run the machine remotely via VNC, or you can
temporarily connect a terminal (or portable PC running an emulator) to a
serial port.
P.P.S. I'm using the P21 BIOS.
It's been a while, but I'm fairly sure that the G6-400 motherboard BIOS allows
keyboard-less operation. Mouseless is not a problem... Ben Myers
On Sat, 10 Jul 2004 15:27:02 +0100, "John Fryatt" <jrf1@ntlworld.com> wrote:
>Hi,
>Regards, John
>serial port.
You should be able to boot the system with a keyboard attached, and then
remove the keyboard.
"John Fryatt" <jrf1@ntlworld.com> wrote in message
news:ccou9v$dhr$1@news8.svr.pol.co.uk...
> Hi,
will
know
> Regards, John
> serial port.
yOn Sat, 10 Jul 2004 15:27:02 +0100, John Fryatt <jrf1@ntlworld.com>
wrote:
> Hi,
Can't say for sure. But I just run my headless PCs in basement with
keyboard and mouse attached (one is my pppoe/masq/router). I normally
access them with ssh (or Putty in Windows). But in a pinch, I could
simply connect a monitor.
David Efflandt - All spam ignored http://www.de-srv.com/
Hi Ben,
Any idea how/where one would set that up. I can't see anything.
John
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:40f00db6.3022808@news.charter.net...
allows
wrote:
> >Hi,
Linux.
mouse.
will
know
> >Regards, John
> >serial port.
Well, yes. I guess I could do that. The keyboard could just lay on top of
the system unit.
One reason I was asking about this is that I saw a Sun Ultra for sale and
looked it up. Apparently these are designed to be run headless, and if they
don't 'see' a keyboard etc. on boot they go to the serial port looking for a
terminal. Just thinking about how a PC could be set up similarly. It makes
for a neat arrangement if you don't have unnecessary clutter around.
John
"David Efflandt" <efflandt@xnet.com> wrote in message
news:slrncf0d7c.2e0.efflandt@typhoon.xnet.com...
> wrote:
> > Hi,
UK
Linux.
mouse.
will
know
It's been quite a while since I last saw them but I remember that there were
switches that permitted running multiple cpu's from a central location with
one keyboard and monitor. Don't know or remember who made them though.
news:CHZHc.1205$325.137@newsfe3-win.ntli.net...
> the system unit.
they
a
> John
> > wrote:
> > > Hi,
> UK
> Linux.
> mouse.
PC
> will
running
Anyone
> know
That might be ok, if the system doesn't fall over without the keyboard once
up and running. I was kind of planning to run the server 24hrs. I'll give it
a try.
John
"Edward J. Neth" <ejn63@netscape.com> wrote in message
news:nQVHc.3106$sa1.2698@newssvr17.news.prodigy.com...
> > Hi,
UK
Linux.
mouse.
> will
> know
> > Regards, John
> > serial port.
John, I have a G6-400 and recently erased and re-formatted the HD. In
trying to find and install the original Gateway drivers for the
Multi-function keyboard I turned off the system, unplugged the PS/2 keyboard
and then restarted. It booted up fine. No messages or anything. I'm using
WinXP. Turns out the drivers were on the original Restoration CD.
> Hi,
will
know
> Regards, John
> serial port.
Ken, you're a star! I tried the same my machine and, as you say, no
problems at all.
Just goes to show how you can make assumptions and look for answers to
problems that don't even exist.
I should have just tried it first!
Thanks, John
"Ken" <mnkwms@comcast.net> wrote in message
news:yYOdnef7LIW0T23dRVn-tA@comcast.com...
keyboard
using
> > Hi,
UK
Linux.
mouse.
> will
> know
> > Regards, John
> > serial port.
They are called KVM switches. Some have 2 ports with cables, and some
have more ports (but cables not included). They allow operating more than
one PC with same Keyboard, Video (monitor) and Mouse.
I had mixed results when configuring an older PC with Mdk 7.0 for serial
terminal (via minicom on adjacent PC through null modem cable). In that
case if I configured serial console for Linux (append="console=ttyS1,38400
console=tty0 hdd=ide-scsi"), I could NOT see boot messages from serial
port (except in logs). If I also enabled serial during boot in main
section of lilo.conf (serial=1,38400n8), I could see boot messages fine,
but login screen response was very sluggish (seconds for each char to
appear). In neither case could I see the LILO menu.
Some server machines (even Intel cpus) can be totally configured and
controlled (even CMOS setup) from serial port, but not most home machines.
>> the system unit.
> they
> a
>> John
>> > wrote:
>> > > Hi,
>> UK
>> Linux.
>> mouse.
> PC
>> will
> running
> Anyone
>> know
http://www.autox.chicago.il.us/ http://www.berniesfloral.net/
Davod,
Thanks for your advice. I did kind of wonder about that, 'normal' PCs not
really being designed for running as headless servers. The thing was kind of
triggered by seeing a cheap Sun Ultra for sale, which is designed to run
headless. Maybe I'll get one of those, or a purpose made Intel server
machine....
Regards, John
news:slrncf34dj.foh.efflandt@typhoon.xnet.com...
were
with
of
> >> the system unit.
and
> > they
for
> > a
makes
> >> John
> >> > wrote:
> >> > > Hi,
the
> >> UK
> >> Linux.
> >> mouse.
the
> > PC
> >> will
> > running
> > Anyone
> >> know
normally
Do you want to mess with a Sun Ultra and Solaris?
You don't necessarily need a more expensive purpose-built Intel server. Just
standard motherboard with a BIOS that allows headless operation... Ben Myers
On Mon, 12 Jul 2004 10:34:59 GMT, "John Fryatt" <jrf1@ntlworld.com> wrote:
>Davod,
>machine....
>Regards, John
>were
>with
>of
>> >> the system unit.
>and
>> > they
>for
>> > a
>makes
>> >> John
>> >> > wrote:
>> >> > > Hi,
>the
>> >> UK
>> >> Linux.
>> >> mouse.
>the
>> > PC
>> >> will
>> > running
>> > Anyone
>> >> know
>normally
news:40f28e19.2153404@news.charter.net...
Well, I might, just for the fun of it. ;-)
Seriously, it would (might) be a useful thing to have on the CV.
Having said that, I kind of get the feeling, from reading the press etc.
that Sun are in recession and Linux is on the rise, so maybe I don't want to
mess with Sun....
Just
Yes, that would probably do it. I was just thinking about David Efflandt's
comments and thought a machine designed for this type of use might be
'better'. Depends on cost really. If I got a cheap (cheap!) Sun or server
box that might be ok, but otherwise I'd go with an normal Intel machine.
John
>Ben Myers
> >Davod,
of
> >machine....
> >Regards, John
there
> >were
location
> >with
though.
than
serial
that
fine,
machines.
top
> >of
> >> >> the system unit.
sale
> >and
if
> >> > they
looking
> >for
> >> > a
> >makes
> >> >> John
<jrf1@ntlworld.com>
> >> >> > wrote:
> >> >> > > Hi,
in
> >the
> >> >> UK
running
> >> >> Linux.
or
> >> >> mouse.
> >the
> >> > PC
> >> >> will
> >> > running
> >> > Anyone
> >> >> know
with
> >normally
could
