Hi there,
Recently I read a forum that claimed you can play bf3 alpha beta on high settings using a gtx460 and get 40-60fps, with 30+ at intense moments. As I understand it, the final product will be optimized and you'll be able to push out more frames with the same hardware. I was thinking of getting either a 6850 or 6870 since they're both better than a gtx 460 and at my local store, in fact cheaper. Is this a good choice for playing bf3 on high settings on a 28' monitor, hopefully at 1080p?? Is there a processor I should be looking out for?? I know that the recommended gpu is either gtx560 ti or 6950, but will a 6870 be enough??
Thanks for your time
