Hello all. Was planning on going PII x6 for a while, decided to be cheap. Running a Dell Optiplex 745 upgraded w/8GB DDR2-800, 2x WD5000AAKX SATA drives, and Radeon 5450 650/800Mhz, using stock Pentium D 945 (3.4Ghz, dual-core, 4MB cache) on Win7 Enterprise 64-bit (re-branded Ultimate), onboard audio and NIC.
So far I can play all the games I have (Morrowind 1600x1200, max settings), Civ4 (1280x1024, max settings), Starcraft (800x600 I believe?), Oblivion (1280x1024, max view distance, medium quality), and Starcraft 2 (1280x1024, low settings).
My current upgrade path includes one component monthly. My next upgrade is a Core2 Q6600, which should be substantial, but won't boost my graphics settings as the 5450 is very limiting.
So, my next upgrades after include a high-quality 650W power supply, and then a new video card, then a quality 1920x1080 LCD.
But which card?
My goals are to be able to run SC2, Oblivion, and Civ5 (will be buying Civ5 after the upgrades) at 1920x1080. Anti-Aliasing is not really a necessity as jaggies aren't a real issue even at 1280x1024, at the full HD resolution this should be almost non existent w/o AA. I'd like to be able to max out said games otherwise (maybe even play TES5-Skyrim w/possibly reduced settings).
So far the bare minimum I'm seeing is a Radeon 5670 or a GeForce 450 w/a 1GB buffer.
At this point I've read many reviews, consulted Tom's VGA charts, and shopped Newegg (my preferred supplier). I'm left without a solid answer though, as recommendations vary from 5670s all the way up to 6870s, or GTS450s up to 560Tis.
I'm willing to spend up to $200 on the Video Card, and my minimum requirements are SC2@1920x1080 maxed (for except AA, that would only be a bonus)
Recommendations from experience please?
But which card?
