RX 480 VS GTX 960 FPS Difference !!
Fady__gamil
165
My PC
INTEL CORE I5 3340,3.1GHz
GIGABYYE GEFORCE GTX 960 WINDFORCE 2X OC 2GB
KINGSTON HYOER X FURY BLUE 8GB 3.1GHz
I'm Planning to upgrade my GPU to Radeon RX 480 4GB
1-Can anyone tell me how the difference of fps between my GTX 960 AND RX 480 Will be??
2-Will my cpu fit the RX 480????
these are average numbers techpowerup got when testing the 480 and 480 xfire. they averaged the performance over all the games and posted these numbers comparing. as you can see the 960 is not even in the same league as the 480. roughly 55-60% of the 480's performance depending on resolution
Your CPU will do, the RX 480 is just like a GTX 970, so it's way better than the GTX 960.
Comparisson between RX 480 and GTX 960
You can see about 17 fps difference in games like The Division, The Witcher 3 and Rise of the Tomb Rider.
