Question rx 570 stuck at 300mhz and 30v
Mar 18, 2020
51
my graphics is stuck at 300mhz msi afterburner was showing that and the amd software. tis problem started after puting my pc in a new case
maybe that means that the pcie cable is damaged i have a modluar power suplly and another cable shoulkd i try? or thates maybe another problem because i buyed the card used
specs
rx570
ryzen 3 3200g
8gb ram 2666mhz
240 westren green ssd
80+ GOLD SILEMTIUM 550W
Sep 6, 2020
98
4
35
bro check once if u installed all the components agian perfectly ( maybe u missed a wire or u didnt properly insert gpu or something else)
Mar 18, 2020
51
can u properly explain tthat context
SO i was lokking on thew internet about this problem one had teh same issue rx570, used ,running at 300mhz while gaming somone said maybe 1st buyyer was overclocking it and something happened so the gpu set self into safe mode where it runs 300mhz
Mar 18, 2020
51
specs
rx570
ryzen 3 3200g
8gb ram 2666mhz
Sep 19, 2020
