[SOLVED] RX 570 temp and fans
Reza_15
52
Hi
I have bought a gaming pc with "RX 570 Gaming 4 gig" graphic card.
When I play fifa 19 with medium graphic, gpu temperature goes upto 60,(not higher) and fans are not working!
Some times when no game is running only one of two fans is working on low speed and some times both of them are working fore some seconds.
Is that normal?
*** I use gpuz to find gpu temp
*** I have latest driver
*** pc has 8 gig ram
*** cpu fx 8350 octa core 4gh
Hey!
This is normal. AMD comes with passive cooling mode and it's designed like that to cut down the noise so your fans won't spin unless they reach +60c which is a decent temperature under load. You can however increase the fan speed manually using MSI Afterburner which will have them spinning all the time.
Hey!
Reactions: Reza_15
