Hello,
I bought an RX 5700 to fit my Ryzen 5 3600 in hopes I could finally play my main game Path of Exile without fps drops unter 60. Sadly there seem to be some driver or optimization issues with the Game. Even tho I play without a framecap the RX 5700 wont give 100% of its power and does't even clock up to its max shaderclock. While just standing in town I get about 80% GPU load but when I go into some more performance demanding action the shaderclock and GPU load drop while my fps are also dropping.
I made a little video showing 3 min of gameplay with GPU, CPU and fps stats which show that exact problem:
View: https://www.youtube.com/watch?v=dTImfnsCkys
GPU/CPU stats in top left and FPS in top right (sry for the german language but I'm sure you can figure it out)
You can clearly see the shaderclock is barely crossing the 1000MHz ever while GPU load is sitting at 60-80% but my frames are constantly dropping to 40 and lower. Weirdest part about it I get 100% GPU load and 1700MHz clock in the menu as you can see in the very end. Also it cant be CPU bottleneck because CPU is barely reaching 50%.
Things I've already tried to fix the Issue:
-fresh windows install
-tried some older driver versions
-messed around with all the ingame settings
-messed around with overclocking
-set every windows and radeon driver options to high performance
-haven't tried other games but I did the Heaven benchmark which was able to utilize to the full load of the GPU
-set PCie to 3
-cried 4 times
none worked
If there is no fix to this issue because the driver is simply <Mod Edit> I will definitely try to refund the card and get an NVIDIA card instead
Hope somebody has a good solution for this.
-set PCie to 3
-cried 4 times
none worked
