[SOLVED] Rx 580 nitro+ dual bios issue, NEED SERIOUS HELP!!!
Faaz__
41
I have an rx 580 nitro+ 8gb gpu with dual bios; The issue is that it was a mined card and while it worked perfectly when the bios switch was on the right side(towards the ports) gpu z would report clock speed of 1340Mhz and memory clock of 2000 BUT on the left side (towards the fan) it was 1150mhz clock and 2250mhz memory(Which is Obviously WAY off). I followed this guide(https://www.techpowerup.com/forums/...sly-a-mining-card-stock-bios-required.257947/ ) to flash the left side bios and now when I start with the switch on left the boot screen shows up full of purple dots; I can still use the port side(switch on right) bios fine but How do I fix the other side? Any help at all would be GREATLY apreciated!!
My rx 580 is the same as the guy in the link I provided.
My full system is Asus H81M-E With 8gb ddr3 ram and i5 4590!
Never mind I fixed it... Here's how for anyone in a situation like mine: First of all my card was a different serial number then the dude in the link I provided, My rx 580 nitro+ serial no. was A-174300004873 his was: A-181500005922; that might be the reason my card decided to show artifacts and not really even boot up fully.
So what I did was started the system up with the working bios(Switch towards the ports) Went into safe mode and used DDU to completely wipe out drivers which made it so the card could boot up into OS even with the faulty bios when I pulled the switch towards the fans after which I download this BIOS https://www.techpowerup.com/vgabios/197967/197967 Its an un-verified bios but works without a single issue...
So what I did was started the system up with the working bios(Switch towards the ports) Went into safe mode and used DDU to completely wipe out drivers which made it so the card could boot up into OS even with the faulty bios when I pulled the switch towards the fans after which I download this BIOS https://www.techpowerup.com/vgabios/197967/197967 Its an un-verified bios but works without a single issue thus far(if any issues do come up I will be sure post about em)
