I've recently bought the rx 6700 xt, worked fine. However, im not sure when exactly but recently i noticed on higher end titles where it wouldn't completely max out fps (like CS:GO), the fps drops would be CRAZY and completely unplayable (very frequently it would drop close to zero). I then proceeded to update ALL my drivers, from cpu, motherboard to the gpu. The fps slightly improved but still generally had crazy bad fps drops. I started looking into hwinfo and msi afterburner and finally noticed that my gpu usage AND core clock frequency would both drop very frequently while in game. This DIRECTLY correlated to the occurrence of fps drops, moreover the core clock speeds where spiking down to UNDER 70mhz! on almost EVERY spike (the spikes where occuring every second or 2).
Key info:
- driver updates on all my hardware
- no overclocks
- tried different games and occurred in every game
- CPU and GPU usage in fortnite is 45% and 40% respectively, with maxing out 165fps on medium (apart from fps drops reaching 1 FPS)
- GPU temps are stable under 50C in fortnite, does not even reach 65C
- 16GB ddr4 Memory
- plenty of storage space
- bought fairly recently as well a new corsair 750W 80+ GOLD certified psu
https://ibb.co/hFXMj5P, in that image you can see the spikes in the 3rd graph of the core clocks which tank the fps to almost none.
Thats all i can think of, any help or recommendations would be GREATLY appreciated
Key info:
- no overclocks
- 16GB ddr4 Memory
