Hi all,
I recently build my new PC and was testing with some AMD Adrenalin settings. In a video of Jayz it was explained that the auto OC/rage mode in the amd software is okay to enable if you are not willing to manually OC or tweak settings. While testing the auto OC feature I noticed the fans are really loud, I recorded it: https://imgur.com/a/861iKS5 Is this amount of sound normal for fans at about max RPM?
Any suggestions for custom settings: fan curve, undervolt etc are welcome. Currently my GPU is about 71-74c with junction at 84c while playing Red Dead 2 on high settings on a 2k monitor (default AMD settings).
Thanks in advance.
PC SPECS:
PCPartPicker Part List: https://nl.pcpartpicker.com/list/7xxJv3
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (€467.90 @ Azerty)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler (€80.47 @ Amazon Netherlands)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard (€240.85 @ Megekko)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory (€110.85 @ Megekko)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€111.85 @ Azerty)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card (€985.04 @ Azerty)
Case: Corsair 4000D Airflow ATX Mid Tower Case (€89.90 @ Amazon Netherlands)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€159.90 @ Amazon Netherlands)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan (€10.49 @ Amazon Netherlands)
Thanks in advance.
PC SPECS:
