[SOLVED] Ryzen 2300x CS GO fps drop problem
Feb 3, 2020
16
Hi everyone, I have a problem with my Ryzen 3 2300X. The problem is the constant FPS drops, friezes, micro-friezes, not a good response in the game.
When I bought and assembled the computer everything was fine, and everything was ok, but after that I updated the BIOS, updated the Windows drivers, these problems started.
When I shoot or play my movements are not the same as they were on my old processor from Intel, the response in the game itself got worse. Also, when many players on the server my FPS drops. It became uncomfortable to play, bad spray control, bad shooting, bad movement.
VIDEO:
View: https://www.youtube.com/watch?v=csH2WiqzdN4&feature=youtu.be
CS GO SETTINGS: ALL LOW: 1024x768
LAUNCH SETTINGS: -high -freq 240 -refresh 240 -novid +fps_max 0
MY PC:
CPU:
RYZEN 3 2300X
MOB: MSI B450-A PRO
GPU: MSI GTX 1660TI GAMING X
SSD: M2 WD 240GB (system)
HDD: 1TB WD MINI
RAM: G.SKILL 3000MHZ 8GB (SINGLE RANK)
CPU COOLER: GAMMAX 200T
POWER SUPPLY: SEASONIC M12II EVO 620 WATT
MONITOR: HP OMEN X 240HZ (DISPLAY PORT)
LAST BIOS
LAST DRIVERS
LAST GPU DRIVER
BIOS SETTINGS:
https://prnt.sc/qsl8fe
https://prnt.sc/qsl8pu
https://prnt.sc/qsl8rc
https://prnt.sc/qsl8xy
https://prnt.sc/qsl91p
https://prnt.sc/qsl962
GAMING MODE: OFF
GPU SETTINGS:
https://prnt.sc/qsl9dq
https://prnt.sc/qsl9gk
https://prnt.sc/qsl9i0
POWER OPTIONS:
https://prnt.sc/qslajk
AIDA64 CACHE AND MEMORY BENCHMARK:
https://ibb.co/nm8RR80
STABILITY TEST 10 MIN:
CLOCKS:
https://ibb.co/WvjkS1X
COOLING FANS: https://ibb.co/28TFFWP
POWER: https://ibb.co/rsNvszV
TEMPERATURES: https://ibb.co/fk5hYwK
UNIFIED: https://ibb.co/tXHy0G6
VOLTAGES: https://ibb.co/BZcPhvb
STATISTICS: https://ibb.co/SXVXf7y
I tryed to use XMP profile doesn't help,
I tryed to use precision boost overdrive doesn't help
I tryed to overlock my cpu doesn't help
I tryed different timing and different speed of ram doesnt help
I turned off High Precision Event Timer in Windows 10 - it helps a lot, but still i have fps drops, but response in the game is better
I noticed that 14 timings and 3000 memory speed are the most optimal for me.
I don't know why but when I change command rate in DRAM Configuration from 1 to 2 game is more smooth.
Check your CPU and GPU usage. Your super low resolution is taxing the processor more. I suspect a higher resolution, to actually make use of your GPU, may help alleviate some of your issues. Even in CSGO, a pure quad core, can experience such symptoms, as there are still Windows related tasks, running in the background. Also, check your temps to make sure you are not overheating.
🤔No more stuttering and freezing? I had a feeling the CPU was the problem. Perhaps it was bottlenecking your GPU.
no my friend, it was problem with ryzen cpu which is not optimized for cs go at all. I search and found that a lot of people have same problem with ryzen cpus. But other games like GTA, Assassins very playable
