So this is the first time I've actually used Ryzen stock. Out of the box I OC'd to 4.2ghz on all cores at 1.365v completely stable until now.
Assuming my OC has become unstable, I'm using stock 3.6ghz with 4.2ghz boost. Now, I know it only boosts on one or two cores and I've seen countless threads with people having this explained to them, but when I look in Hwinfo64 I cannot see any of the cores boosting above 3.6ghz. Should I be able to? Or are the cores not boosting?
If not, what do you suggest I change to gain the boost? I have enabled it within BIOS and it's set to auto.
Thanks in advance
Edit: just downloaded Ryzen Master to check it out, and where it says "auto/precision boost/manual" it is set to manual and i haven't changed anything. Have I possibly missed a motherboard setting?
Thanks in advance
