I bought a Ryzen 3600, and i dont plan to overclock it. I just bought a Hyper 212 black edition as aftermarket cooler (after reading multiple reviews of people complaining about the stock cooler). Is it worth spending 40 euros on that? or should i cancel the order and get a refund?
Bro your aftermarket cooler is ok for the following reason:
1 its completely worth it if you live in an hot climate like mine where the ambient temperature reaches 35 deg C in summer,
2 If you wanna overclock then you should go for liquid cooling, And i myself use Antec A400 i cannot overclock much with this cooler but keeps my CPU temperature under check,
it does 43 idle and 70 in gaming. before the Stock cooler used to keep my cpu at idle 55- 60 and gaming right near the Threshold of 85deg.
So yes the custom cooler keeps your CPU cool, thereby increasing its longevity.
