CPU: Ryzen 5 1600x
Motherboard: b450 f gaming
Cooling: nzxt m22
P/S: EVGA 750bq
GPU: gtx 980
When computer first fires up temps are already in the high 60's low 70s.
After about 3 minutes of use they jump to 75 and stick. NO fluctuation after 75.
Prime95 stress test doesn't have an effect. Idle and under stress both at 75.
Bios reports same temperature.
HWMonitor CPU Temp is stuck at 75, CPU Socket temp at 32, Chipset temp 42: all stuck
I monitor on HWMonitor, CAM, Ryzen Master, and Core temp.
Recent troubleshooting:
I have removed all components, full clean out of case, Cleaned and re-applied thermal paste.
Followed NZXT's forums advice for checking air bubbles in m22. Swapped Radiator location to both recommended spots.
New BIOS update.
Sometimes(rarely) i will get a popup of 81 degrees warning then temp will go back to 75 and stay.
Cooling: nzxt m22
P/S: EVGA 750bq
GPU: gtx 980
New BIOS update.
