Ryzen 5 2600 CPU temp values
Victor_3
52
I finished my build today (yay for me!) and only now at night I installed Speccy to see what temperatures are inside my case and I suddenly almost had an heart attack.
I saw 100ºC (212 Fº) on my CPU and start sweating wondering if I installed the cooler wrong.
Then I installed HWMonitor aswell CoreTemp and the results were ~45ºC (113 Fº)
Which one represent the true value? I'm really worried about this but I was playing and browsing the internet all day and didn't had any problem...
First, get rid of Speccy. That is practically worthless and rarely accurate.
Second, download and install HWinfo, which is like riding a full dress cruiser compared to a powered bicycle (Speccy). LOL.
Core Temp can be trusted, it is a regularly updated program that has the trust of the enthusiast community and seasoned builders. I like to use it in conjunction with HWinfo.
HWmonitor, Open hardware monitor, Realtemp, Speccy, Speedfan, Windows utilities, CPU-Z and most of the bundled motherboard utilities are often not the best choice as they are not always accurate. Some are actually grossly inaccurate, especially with certain chipsets or specific sensors that for whatever reason they tend to not like or work well with. I've found...
HWmonitor, Open hardware monitor, Realtemp, Speccy, Speedfan, Windows utilities, CPU-Z and most of the bundled motherboard utilities are often not the best choice as they are not always accurate. Some are actually grossly inaccurate, especially with certain chipsets or specific sensors that for whatever reason they tend to not like or work well with. I've found HWinfo or CoreTemp to be the MOST accurate with the broadest range of chipsets and sensors. They are also almost religiously kept up to date.
CoreTemp is great for just CPU thermals including core temps or distance to TJmax on AMD platforms.
HWinfo is great for pretty much EVERYTHING, including CPU thermals, core loads, core temps, package temps, GPU sensors, HDD and SSD sensors, motherboard chipset and VRM sensor, all of it. Always select the "Sensors only" option when running HWinfo.
In cases where it is relevant and you are seeking help, then in order to help you, it's often necessary to SEE what's going on, in the event one of us can pick something out that seems out of place, or other indicators that just can't be communicated via a text only post. In these cases, posting an image of the HWinfo sensors or something else can be extremely helpful. That may not be the case in YOUR thread, but if it is then the information at the following link will show you how to do that:
*How to post images in Tom's hardware forums
Run HWinfo and look at system voltages and other sensor readings.
Monitoring temperatures, core speeds, voltages, clock ratios and other reported sensor data can often help to pick out an issue right off the bat. HWinfo is a good way to get that data and in my experience tends to be more accurate than some of the other utilities available. CPU-Z, GPU-Z and Core Temp all have their uses but HWinfo tends to have it all laid out in a more convenient fashion so you can usually see what one sensor is reporting while looking at another instead of having to flip through various tabs that have specific groupings.
After installation, run the utility and when asked, choose "sensors only". The other window options have some use but in most cases everything you need will be located in the sensors window. If you're taking screenshots to post for troubleshooting, it will most likely require taking three screenshots and scrolling down the sensors window between screenshots in order to capture them all.
It is most helpful if you can take a series of HWinfo screenshots at idle, after a cold boot to the desktop. Open HWinfo and wait for all of the Windows startup processes to complete. Usually about four or five minutes should be plenty. Take screenshots of all the HWinfo sensors.
Next, run something demanding like Prime95 version 26.6. Take another set of screenshots while running that (Small FFT option) so we can see what the hardware is doing while under a load.
*Download HWinfo
45 degrees is rather high, if that is an idle temp, but idle temps are practically irrelevant unless the maximum temperature is above 80°C, THEN it might indicate a problem or a lack of cooling. Often, a poorly seated CPU cooler or a bad paste job are to blame. Still, if your max temps are below 80°C, I would not be worried, at all, about a 45 degree idle.
