Question Ryzen 5 3600 max turbo boost OC
Jul 29, 2024
Hey, I would like to ask, if there is an option to overclock this CPU the way that it boosts higher then out of the box max turbo boost? I'm currently running all core OC 4.3GHz at 1,3V but I don't like it because I don't need this performance all the time and it's unnecessary load for the fans and pc overall. I only need it when I play more CPU demanding games like World of Warcraft or Kingdom Come Deliverance. So my question is: is there a way to let my CPU behave as out of the box so it will run most of the time 3.6GHz base frequency but it will boost more than default 4.2GHz during turbo boost? Btw I'm completely new to OC so keep it in mind during explanation please.
My specs are:
CPU: Ryzen 5 3600
MB: MSI B450 TOMAHAWK MAX
Cooler: Noctua NH-D15
RAM: DDR4 3200MHz
Simple: Remove the CPU OC completely and let the CPU itself to decide when it needs to boost the frequency up or not.
There is a reason why turbo boost goes up to 4.2 Ghz and not 4.5 Ghz or 5.0 Ghz on R5 3600. If you want the CPU frequency to be more than what max turbo can do, you have to manually OC it, like you've already done. But this removes the "on demand" or "adaptive" frequency changes which is default mode of the CPU.
But if you absolutely need 4.3 Ghz adaptive turbo, then upgrade your CPU. E.g R5 5600X has base 3.7 Ghz but can turbo up to 4.6 Ghz,
specs: https://www.amd.com/en/products/processors/desktops/ryzen/5000-series/amd-ryzen-5-5600x.html
Or any other Ryzen 5000-series CPU, who's turbo clocks are to your likening,
lineup: https://www.amd.com/en/products/processors/desktops/ryzen.html#tabs-0eb49394b2-item-dfd73644d4-tab
Reactions: drea.drechsler
So there is no possible way to boost just the turbo boost by some multiplier or something?
Yesy you can.
But will it be stable is the question.
You can raise the multiplyer or you can set a 200-300-400- boost override in the bios on most boards.
Check the AMD overclocking section.
Can you explain it in little bit more detail please? What exactly is the multiplayer setting called and where to find it? Same with the 200-300-400- boost override.
Precision Boost Overdrive (PBO) will never boost past the max boost clocks of a CPU. It may hold the boost clocks longer but it will not achieve what OP is looking for.
Best would be Steve's (GamersNexus) in-depth explanation about PB, PB2 and PBO:
View: https://www.youtube.com/watch?v=B7NzNi1xX_4
Precision Boost (PB) and Precision Boost 2 (PB2) are the default/vanilla methodology for Ryzen CPUs boost function.
In the video, at 12:21, you can see BIOS setting for "Max CPU boost clock override" that changes the PB2 algorithm. You should be able to increase that by increments of 25 Mhz, up to +200 Mhz. Or decrease it up to -1000 Mhz (if decrease option is available). Your MoBo may have the same setting. However, CPU may not be stable once you increase that value, in hopes of achieving what you seek for.
Reactions: TheSormon
