I upgraded from an overclocked AMD FX-6300 to a Ryzen 5 3600 last May and I've been noticing considerably hotter CPU temps compared to my old setup. I've heard that FX processors reported their temps differently (not sure how though) so maybe the comparison is moot.
My FX was cooled by a CoolerMaster Nepton 140XL and that system is still running as my parents home PC. CPU temps at idle are currently about 20-30C and 50-55C under load which seems suspiciously low since the thermal paste has not been changed since installation ~6.5 years ago. I've never had to check the pump or anything.
Now my Ryzen 5 3600 is cooled with the stock cooler. After installation, CPU temp hovered around 50C at idle and in the past couple of months has been creeping up until I saw 95C under load early last month. That scared me so I first tried adding a fan to the case flowing out right above the CPU. No change in temps. Yesterday, I decided to change the thermal paste from the pre-applied stock thermal paste to Arctic MX-4. I got maybe a 3-5C change in idle and barely any change in load temps, so I reapplied the thermal paste thinking I did it wrong and saw no further changes. Then I went into the BIOS (Gigabyte B450M DS3H) and adjusted the CPU fan curve to run at 100% all the time. The stock CPU cooler fan is not very loud at all so that doesn't bother me. Now idle is about 40C and under load it goes up to 88C. This feels too hot to be "normal" even with the stock cooler. I don't want to spend $80-$120 on a new cooler if I can avoid it right now, but it could be a little Christmas gift to myself if it's necessary. Given my luck with my FX CPU temps, I'm inclined to go water cooling to reduce noise and temps, and if the temps are considerably cooler, I could overclock to bring them back up
So the questions: is 88C under load (I've tried minecraft and prime95) acceptable/normal with the stock cooler? Would getting a hefty air cooler or water cooler be worth the cost? Is my CPUs life at stake here? Thank you!!
