[SOLVED] Ryzen 5 3600 stock cooler temps
smartmantech47
447
19
4,695
Hi guys, pc builder here. I'm planning to build a pc (nvm gpu prices in my country they're normal) and I want to ask about stock cooler temps with the ryzen 5 3600 temps. If anyone used it with the stock cooler, what are the temps while gaming and what's the noise experience? If someone used it while rendering, what are the temps too? Thanks :)
Motherboard, you still on going for Ryzen?
For Ryzen,
a choice.
For Intel something like this,
https://pcpartpicker.com/product/m2...tx-lga1200-motherboard-mag-b560-tomahawk-wifi
I would rather get a motherboard without wifi and get something like this,
https://pcpartpicker.com/product/dB...x1-80211abgnacax-wi-fi-adapter-archer-tx3000e
this let's you move the antenna around so you can look for the best signal. Have to say that the difference between for instance the Asus TUF boards with or without wifi in money will be less.
Yeah okay then. I'm sorry but, if you can give me an ATX mobo with wifi under 200 bucks in the UAE I'll be very thankful. I know the good mobos and the not very nice ones, but my mobo in my build seems nice. If you recommend atx tho then please help me find one. Thanks. Also, if there's a way to decrease the cost of my build, like going with the RM850 for example, or going with 240gb ssd for example, please, tell me. Many thanks.
For Ryzen,
a choice.
Thanks. I'll search for a b550 in that price range tho. Can't I stick to the b550m plus wifi from Asus?? I'm getting a not so expensive build since I'll be upgrading to am5. And also, do you think I should get the ryzen 3 3100 or the 3600? Both fulfill my needs
Sure, is a good option.
Personnaly would i get the 3600, it wil go just a longer way and the xtra threads really will help, but think noone has asked what the pc is for so ..... what is the pc for, what are you going to do with it?
For the mobo I've changed my mind, my budget is limited to 130 dollars. If you could help that would be wonderful. I'd have no problems with b450, b550, and A520. I've found the b550m ds3h. Good enough? 100 bucks. I'm not keeping the pc for long as I said, so I'm going to go with the 3100. A bit of rendering, video editing, light gaming, and productivity work. Nothing too serious,
For me as long as the board falls into the ''acceptable or good enough'' I'm happy. As long as there's a fan header for a cpu fan and a chassis fan I'm fine. For usb headers minimum of 5, and for the soundchip I don't care as long as I can hear things clearly.
I've found out that the ds3h is good except that I'm concerned about the 5+3 phase. Is it good(
Like i said for the Ryzen 3100 is it fine, when you get into the territory of 125watt tdp cpu's might it become a problem. So the 3600 is likely fine as well although the 3600x is a 125tdp cpu not sure likely fine, the 3700x i'm not sure about, but the 3800 and up would i avoid. But since this is a temporary system as you say it is it not the plan to upgrade from what i read.
Would myself go with a better motherboard so you could maybe get a better cpu in it just because if Ryzen 5 is not what you'd expect it to be or hope for you could just upgrade, but i get that you have a limit in budget now.
