Question Ryzen 5700x PBO tips
Dropment
852
I have pbo on advanced with curve optimizer at -20. My PPT at 120, TDC at 75, EDC at 110. I am fairly new at using PBO not sure what I should do.
My specs are
arctic liquid freeze 360 aio
MSI B550 Tomahawk
Ram overclocked to 3733 14-14-14-26
Looks about right, my setup is similar but with -15 on all cores but the 2 most used, those are -20. I have + 200mhz. I might have tdc set to 85...
You can use hardware monitor to check and see if TDC is maxed, you can bump it up more if you like assuming CPU and board temps are ok.
I don't have PBO on for anything, just using the values above.
