I built my very first PC in February of 2021.
Specs:
CPU: Ryzen 7 5800x
CPU cooler: MSI MAG 240G AIO
Mobo: Asus Prime x570
RAM: Gskill 16GB Ripjaws
GPU: Radeon XFX 6900xt Merc Speedster
PSU: Super Sunflower 850W 80 Plus Gold
HDD: 2x1TB Nvme drives
For the first time a few days ago, I decided to benchmark my CPU and found that I only got a score of around 10500 in Cinebench R32. I have seen that others online are getting over 15000 for the same CPU.
I noticed that the CPU utilization was not as high as I would expect it to be during the Cinebench run, but looking at the CPU temp in hwinfo I could see that the CPU was running at 90 degrees Celsius. I thought this may be why performance was being hampered - the CPU was getting too hot. During the test, CPU utilization in task manager showed only around 70% - 77%.
I then moved the radiator from being mounted to the top of the case with fans pushing air up and out of the case, to the front of the case with fans pushing air into the case. See the link below for picture I've taken (excuse the poor cable management). This move did not do much, if anything, for the CPU temps.
My PC
I then decided to purchase and apply some new thermal paste. Running Cinebench after that brought my score up to around 11900. Much better but still much lower than I was expecting. During this Cinebench run, CPU utilization showed around 90%.
What I find really strange is that the idle temps of the CPU are very high. Right now I've only just switched on my PC and the CPU temp is over 80 degrees Celsius while idling (!!!!). See Hwinfo screenshots below which shows the temps and speed at which the pump is working (I believe it's running flat-out), as well as CPU utilization in task manager. The CPU is currently idling in these screenshots.
Hwinfo 1
Hwinfo 2
Hwinfo 3
Task manager CPU utilization
I would really appreciate some advice on next steps to take, I really just want to get the performance that I paid for 🙁
Thank you in advance,
Arnoux
Specs:
CPU: Ryzen 7 5800x
My PC
Hwinfo 1
Hwinfo 2
Hwinfo 3
Arnoux
