Question Ryzen 7 2700 does not boost
Dec 26, 2018
13
Hello everyone, I encountered a problem, When playing games or while idle, I noticed that my 2700 does not boost itself to the 4.1 GHz that it's supposed to do, it just stays at 3350 all the time. I tried all putting it to balanced performance mode instead of Ryzen's balanced mode. My pc spec list:
Processor: AMD Ryzen 7 2700
Graphics Card: NVIDIA GeForce RTX 2070
Ram: Corsair Vengeance 16GB DDR4 3200Mhz
Storage: Samsung 850 EVO 250GB, WD Green 1TB
Thanks in advance,
Orizan
Have you tried performance mode? Also, you can check in the power settings to make sure the CPU is set to 100% for it's maximum. What cooler are you using?
I did try putting it into performance mode and it changed nothing, When I put it on the Ryzen Balanced mode I get the best performance while doing tests. The max is at a 100% and I'm using the stock cooler AMD gives you with the 2700 (Wraith spire). Temps don't reach over the 60's.
