Hello, I got a problem with my Ryzen CPU: the temp goes up to 95 degrees when I play or I benchmark my system
I've already tried to use the cooler that comes with the CPU, change the thermal paste, enable the "ECO mode 45W" setting in the BIOS, change the fans position (mount them on the back or on the front of the radiator), and set the energy combination option in the control panel to "energy saver mode", but, obviously, nothing changed.
I think I should downlock the CPU to get lower temps, but every time I tried to changed the voltage or clock speed the computer shutted down. For example, some hours ago, I set the clock speed and the CPU voltage in Ryzen Master to the default manual setting (Clock Speed 3.000 | Voltage 1,1875) and when I applied the computer shutted down.
Maybe there is another solution without dowclocking the CPU, but, as I told before, I've already tried a bunch of things that didn't change the situation.
SPECS:
CPU: Ryzen 9 3900x
Cooler: MAG CORELIQUID 360R
Motherboard: MSI B550 TOMHAWK
GPU: GIGABYTE RTX 3080 Ti GAMING OC
RAM: G. Skill 16GB x2
PSU: Aerocool P7-850W Platinum 850W
Case: Sharkoon TG6
OS: Windows 11
Vids and screenshots
My system shutting down when testing VR perfomance:
CPU Temperature
SPECS:
CPU: Ryzen 9 3900x
Case: Sharkoon TG6
OS: Windows 11
CPU Temperature
