Specs:
Motherboard: ROG STRIX B550-A Gaming
RAM: 32GB 3200Mhz DDR4
CPU: Ryzen 9 5900x
Cooler: Vetroo v240 240mm Radiator
GPU: GT 1030 (Don't ask I had it laying around and it's just a place holder until I snipe myself a RTX 3080)
PSU: Corsair Gold 650w
Alright, my 5900x has really unstable temperatures, when the pc boots up it will jump around between 45c and 75c.
This causes my fans to constantly jump speeds and it's really frustrating hearing them go up down up down
As an example simply launching Minecraft will make the CPU stick jump to roughly 70c however then it will settle down around 40c.
I'm only worried because my CPU's have never jumped around temperature wise like that.
Stress test took it all the way to 91c.
Even when put into ECO Mode 65w it still heats up the same way as if it was in 105w mode.
To compare I tested a Ryzen 5 5600x and the temperatures on that CPU were stable and normal#
I'm no expert in CPU's so maybe this is normal for Ryzen 9's as I've never had them. However if there is a issue i'd rather diagnose it earlier to save myself trouble and get it fixed/refunded if I can. I can supply you with any info you need I can log my HWiNFO sensors if that will be any help
CPU: Ryzen 9 5900x
