mitch074
Splendid
At one time, motherboards wouldn't have XMP profiles to work with - I'm also not sure how XMP would work there, because 1T/2T depends on the total amount of ranks you have.I just double checked, and the timings are all definitely still set to "Auto" in the BIOS. The motherboard I'm using is actually one that has been reviewed here, a Gigabyte Aorus Eilte - one of the cheapest X570 mobo's around.
https://www.tomshardware.com/reviews/gigabyte-x570-aorus-elite-atx-motherboard,6252.html
Long story short, 1 rank per channel usually defaults to 1T, anything more than that (2, 3, up to 4 ranks possible!) the motherboard could switch to 2T. Some kits and motherboards might allow you to go back to 1T with dual rank, but motherboard makers usually try to play it safe with non-simple configurations.
From my (DDR1) experience, 1T on 3 ranks or more usually doesn't work.
