Question Samsung 27 inch curved monitor disassembly
Oct 4, 2021
Hello,
I was setting up vesa mount on the following 27 inch monitor from Samsung,
https://www.samsung.com/au/monitors/gaming/wqhd-curved-gaming-monitor-with-144hz-refresh-rate-and-amd-freesync-27-inch-lc27jg54qqexxy/
when accidentally this screw went inside the monitor hole and now I am unable to take it out since the hole is quite small. Whats even more frustrating is that despite the hole being not that big, the screw went directly inside it (talk about having a bad day).
Now I am trying to dismantle it but I cannot find any manual or anything across the internet. Does anyone has any experience in dismantling it so that I can take out the screw. There are a bunch of screws at the bottom which I have removed and carefully unattached the bottom bezel but I have no idea what to do next.
Perhaps this video could help but it's an actually guide to disassembling the monitor you have. Disassembling the panel without any known issues with the panel can and will void your warranty, I'd leave it as is. Not like you're going to move the monitor around anyway.
I have watched that video. I can google also and find out stuff lol. Did you read the part where I mentioned "vesa"? I am going to move my monitor around, landscape v/s portrait therefore taking out that screw is required. :)
