[SOLVED] Samsung 870 QVO slow write speed ?
Nov 23, 2021
7
Hey.
I have gotten myself as a quick buy a Samsung 870 QVO 1tb SSD to use as a Windows drive because my previous one failed.
The write speed of this drive should be over 500mb/s but mine is only 88mb/s at max. ?
samsung magician gave me this benchmark after 1 hour:
sequential read 550mb/s
sequential write 85mb/s
random read 44433 iops
random write 20507 iops
motherboard is b450m pro4 asrock
ryzen 5 5600x cpu
rtx 3060ti gpu
no idea where to find that,
if write cache is the same as rapid mode in magician i tried turning it on but due to internal errors it turned itself off
No, NOT RAPID mode.
Device Manager
Disk Drives
Right click on the drive in question - Properties
Policies
Verify that "Enable write caching on the device" is checked
This is the diff between on and off on an 860 EVO:
No, NOT RAPID mode.
Device Manager
Disk Drives
Policies
Not to worry.
SSD benchmarks will not reflect the way you actually use the drive.
Once any buffering is used up, the remaining writes will only proceed at the rate the nand chips can manage.
On the QVO units, that capability is not great.
But in actual use, writes come in small bursts.
Most of what windows does is small random reads, and the QVO does an excellent job at that.
Not to worry.
I have read this before, but my pc becomes laggy at times.
Games like nfs heat or forza horizon are unplayable and windows is on this drive too.
This makes the PC lagg immensely
loading into games crashes pc sometimes too.
and getting games on a seperate drive gives same outcome, i have reinstalled windows twice now because i thought it was a windows error
If your ssd test results are similar to what USAFRet posted, I think your lag problems lie elsewhere.
