Hi,
I'm going out of my mind with this one. I recently upgraded my motherboard, RAM, CPU, and GPU, formating the M.2 NVMe drive I used as my OS drive in my old system in an 'ASUS ROG Rampage VI Extreme' (where it worked perfectly for seven years), and installing a fresh copy of Windows 11 via a bootable flashdrive created using the Windows tool.
Upon booting for the first time everything seemed fine, I used GIGABYTE's "out of the box" settings for the CPU, and X.M.P. 1 for the RAM, and the M.2 drive showed up under the "Peripherals" section of the "Easy" mode of the UEFI, which the board defaults to. I installed the GPU and left it at stock settings and everything seemed fine for the first few cold boots.
After a few days of use I started getting the Windows Recovery bluescreen, where I tried "Startup Repair" to no avail, and noticed the M.2 was now not showing under any of the sections it was before. I tried moving the drive to the "M2A_CPU" slot from the "M2C_CPU" top slot since this shares PCIe lanes with the GPU and saw some people suggesting this might work, but it didn't.
After searching forums and watching videos I tried using MemTest64 to check the RAM and that was fine; used Windows Checkdisk in Safe Mode and this reported no faults; enlarged the Boot Manager partition on the OS drive from 100 MB to 500 on the advice of of another Tom's user; installed a fresh Win 11 on an old Kingston 2.5" SSD drive (which works fine and shows up in the BIOS), while I reformatted the M.2 drive again before putting a fresh Win 11 on it; have made sure CSM and Secure Boot are both disabledb however, NOTHING had made a difference until this morning where I decided to try moving the M.2 back to the top position again – which requires taking the GPU out – and lo and behold the M.2 showed up in all areas in the BIOS . . . for a single boot (see Imgur pictures) – then upon cold booting again without the GPU in, it disappeared again and I recieved my old friend the Recovery bluescreen like somebody from your past that you take a 30 minute detour in order to avoid passing thrm in the street of the cold, grey town you swore you'd have left by now . . .
Does anyone have a clue what's going on here? In Samsung Magician and HWinfo the drive is reporting as healthy, and when I do get into Windows – by clicking ESC in the Recovery bluescreen and booting through the BIOS – everyrhing stays on rock solid without issue until I turn off and try and cold boot the next day.
The following is s link to the images I've discussed:
View: https://imgur.com/gallery/FQHYL8g
My specs are as follows:
- GIGABYTE AORUS Z790 PRO X (Rev 1.0)
- Intel i9-14900K
- 32 GB of Corsair Dominator Titanium DDR5 @ 7000 MHz
- RTX 4080 SUPER FE
- Samsung 950 PRO 256 GB M.2 NVMe
- Samsung 850 PRO SSD 1 TB
- ASUS ROG THOR 850W PSU
- NZXT Kraken X72 360 AIO
- Windows 11
Any ideas would be welcome as I had intended to get a more modern, larger capacity Samsung M.2 drive to use as my OS as the 950 PRO was bought in 2017; however, what's the point if this is going to be the result of using an NVMe drive with this mobo?
Thanks
- Intel i9-14900K
- RTX 4080 SUPER FE
- Windows 11
Thanks
