Question Samsung 980 PRO Volume cannot be found
Jun 18, 2023
6
Hello,
I just bought a Samsung 980 PRO 2TB nvme SSD. When I installed the SSD, I attempted to use it to migrate my OS and files from my Crucial SSD to the new 980 PRO.
I initialized the new SSD and was able to get the BIOS, Disk Management and File Explorer to detect the new SSD; however, when I use Samsung's Migration Tool using their Samsung data migration software (Samsung Magician), the new SSD could not be detected. It only detected the Crucial SSD.
I went through Disk Management to make sure the 980 was initialized and had a drive letter assigned. All of that was fine, but when I went to check the Volume of the 980, it kept popping up the "Volume information for this disk cannot be found" error. This made it so that I could not even create a backup of my old SSD onto the new 980 (which I was attempting to do in order to migrate all of my data onto the 980 from the Crucial SSD)
I cannot figure out what I am doing incorrect and am thinking I need to return the new 980.
I have checked for updates for my Win10 OS, the drivers for the 980 and anything else I could look up on the internet. I tried uninstalling and reinstalling the 980 into the mobo.
Currently, I'm using an Aorus x570 I PRO WIFI mobo that has 2 slots for the M.2 nvme ssd. I checked to make sure my mobo would support the Gen 4 980 PRO and it all seems to be fine.
I read through posts here and on the internet and have done the troubleshooting they recommend (update drivers, make sure disk is initialized and a drive letter assigned, used a partition tool to help recreate the partition, etc)
The 980 shows up in disk management, the BIOS, and in the File Explorer as ready to go. I could even save images and documents to it in the File Explorer, but I am unable to migrate my OS to it because of the "Volume cannot be found" error I keep getting
Out of curiosity, how are you migrating the OS onto the Samsung 980 Pro SSD?
I was going to use Samsung's Magician Data Migration Tool. If that didn't work, I was going to just use the old System Image method, but I was/am rusty with it so I thought I'd try the tool from Samsung first. I was going to try any method I could, but once I saw the volume cannot be found error, I couldn't really move forward.
Originally, I planned to use the Minipartition Tool but for some reason, v10 (the free version) would not work at all. It wouldn't get past the startup screen for the tool.
Latest posts
