Hello to all,
I'm just trying to make a simple math here before I purchase a new 49' inch monitor Samsung G9 Neo that has a display resolution of 5120 x 1440 pixels @ 240 Hz frame rate.
With the native resolution, 240 Hz frame rate and a standard 8 bit per pixel depth color (not even 10) it sums up to a data transfer rate/ bandwidth of 53,08 Gbps.
This monitor has 2 types of ports: HDMI 2.1 (48 Gbps MAX) and Display Port 1.4 (32,4 Gbps MAX) and none of them supports this high transfer/refresh rate.
Can someone explain me how this monitor should reveal it's full potential if there is no way for it to receive a data with that rate? And it's not even 10 bit per pix of a color depth - with that the data speed will come up to ~ 63 Gbps
I believe, there is only one port on the market right now that can support this data speed rate - Display Port 2.1 which this monitor doesn't have. Please correct me if I'm wrong.
