Samsung notebook model NP915S3G lights blink and will not charge
monique_6
Commendable
Apr 11, 2016
Samsung notebook model np915s3g will not charge power light blinks and so does power button please help my kids have school on this computer
Hi,
Please do try these troubleshooting steps that I suggested to others that may help.
- Start by doing a hard reboot, remove the battery and unplug the AC adapter then press and hold the power button for 20 seconds then try booting it up again.
- If this will not work, do test the AC adapter if it's working properly. Remove the battery and power the laptop with just the AC adapter connected and see if it will boot up or not. do also try a different AC adapter that has the same voltage and see if it will work or not.
- Proceed with reseating the RAM's if trying a different AC adapter will not work, remove them all for couple of seconds then put them back in making sure everything is seated properly.
- If it will still not work, connect an external monitor and see if you'll get any display from it. If there's a display on the external monitor that could mean that the problem is the built in display.
- But if there's still no display on the external monitor that means the problem lies in the motherboard.
Nothing help me but the other day it started to charge and turn on but once it dead it will not charge again or turn on the lights blink the on button and charge button
