Samsung s9 stuck in safe mode
wiktor.nowak05
75
HELP!! My only phone that is a Samsung galaxy s9 boots only into safe mode upon startup and reboot. It's because I dropped my phone and the volume down button is pressed. I can't get it to get unstuck because the metal casing is warped causing the button to be stuck. I have tried everything to get the button unstuck to no avail. Please help me as I can't use my phone and my apps.
Any warranty left?
In any case, it is likely that the phone will need to be disassembled to straighten the metal case and/or otherwise fix the button.
I am very much one for DIY repairs but additional attempts might make a simple repair more difficult (expensive) or just outright cause more damage.
Find a repair shop that knows how to fix Samsung Galaxy s9 phone.
Reactions: xenthia
Any warranty left?
Isn't there like a program on windows to like boot out of it? I can enable developer mode for example and enable usb debugging if that helps any.
