Question Samsung UR59C 4k 60 hz monitor stuck at 30 hz when using Dell Dock
Mar 2, 2023
I'm using a Samsung UR59C monitor with a Dell dock and Dell XPS 13. Products are linked below (I've confirmed they all support 4k @ 60hz). When using a USB-C to DisplayPort cable directly between the laptop and monitor (my laptop only supports USB-c) I get 4k @ 60hz with no issues. However, using the same cable, a normal display port cable, or HDMI, I can only get 30hz using the Dell Dock.
Monitor (https://www.samsung.com/us/computing/monitors/curved/32-ur59c-curved-4k-uhd-monitor-lu32r590cwnxza/)
Dell dock (https://www.dell.com/en-us/shop/wd1...plays-5-usb-ports/apd/210-azbg/pc-accessories)
Dell XPS 13 9360 laptop (https://www.dell.com/support/home/en-us/product-support/product/xps-13-9360-laptop/overview)
Any help is much appreciated. Thanks
Using the service tags on the laptop and dock respectively, check and see if the dock has any firmware updates pending. I don't have your Service Tag code which is why I've just seen it listed generically as a series;
https://www.dell.com/support/home/en-us/product-support/product/dell-wd19-130w-dock/drivers
Likewise, using your laptop's Service Tag code, see if your laptop is pending any BIOS updates.
I'd also try and use another cable;
https://dl.dell.com/content/manual2...on-wd19-user-guide.pdf?language=en-us&ps=true
page 17 and 18.
page 17 and 18.
page 17 and 18.
Thanks for the reply. After downloading and installing all updates, still facing the same issue. I see that the manual shows DP 1.4, but my monitor only shows 1.2 or 1.1 as options? Maybe that is the issue?
