Hello there! I just bought this GPU and I have a few questions about temperatures and fan behavior.
This is my rig:
5800x3D
MSI x570 A-PRO
16x2GB 3600mhz
Noctua NH-D15
Bitfenix Formula 650w
Corsair 4000D
6 noctua fans (3 intake 3 exhaust)
Resolution is 3440x1440
Idle temps are 35-40c GPU Core, 40c hotspot, 60c memory junction sensor.
GPU reaches 65c on GPU core, 80c on hotspot sensor and 92c on the memory junction sensor when passing synthetic tests like Time Spy or gaming and fans starts to run until 2000-2300RPMs.
And fans behave really strange, zero rpm works fine until GPU hits 50 and then starts to run and stops when GPU drops down to 40c and so on. the problem is that GPU reaches that temp of 50c while navigating (tipically watching videos / Netflix) so the fan cycle repeats every a couple of minutes and its annoying.
Questions:
1. How normal and good are these full load temps? Will they harm the GPU?
2. I have tried to change the fan curve to avoid the behavior when browsing but I think the zero rpm thing is set by the firmware, so unless I flash bios (which I will never do) I suspect that theres nothing to do so the question is, setting low rpms when GPU is idling (like 500-600RPM) will wear away the fans?
That would be my questions, thank you for reading this!
This is my rig:
5800x3D
MSI x570 A-PRO
16x2GB 3600mhz
Noctua NH-D15
Corsair 4000D
Questions:
