Hi, i bought this graphic card 2/3 weeks ago and everything worked fine, i only noticed that while playing games like far cry etc for a while the gpu gets pretty hot, around 70 degrees celcius, (just with some games tho, for the rest it stays always under 60 degrees), but i know that it isnt a gpu problem but its a case problem (when i see that it gets hotter than 68 degrees i stop playing by the way), but anyway here's my problem, while i was playing i had MSI Afterburner turned off, so i didn't know the temperature of the gpu but i could smell a burning smell from it, and i turned the game off right away, and opened the case, i waited like 10 minutes and turned the game on again just to check if everything worked fine, and it did, but this time the gpu had this rattling/vibrating sound, you can only hear it when the fan speed is over 55%, when it gets over 70% you can hear the sound less, otherwise if its under 55% you gotta open the case put your ear inside of it and you can hear it from there, the sound goes "slower" if the fan speed is slow, so i thought it was a fan problem, i removed the gpu detached the fans and check if they worked properly, and it looks like they do, but i can still hear that sound.
I bought this gpu on ebay (it was new) and i dont know if i can and i dont know how to RPM the card, do you guys know how i can resolve this problem? its very annoying.
p.s: i tried to touch the card while gaming, to block the vibration but it doesnt change anything.
this is the sound that it makes, i recorded it http://vocaroo.com/i/s0LOmZ7B9AoA it starts when the fan speed is under 55% and than it goes over 55 and you can start to hear that sound.
