Sapphire Radeon 1gb HD 7850 fans spin up but no display output
aireybairey
4
Hi,
I just bought a sapphire 1gb HD 7850 from ebay and when I just tried to use it, the fans on the card spin up but I don't get any display output.
My components are:
CPU: i5 6500
RAM: corsair 2400MHz 8gb ddr4
Motherboard: Asus B150M-A
PSU: Corsair 430W semi-modular
I realise that the recommended power for the card is 500W+ but I've read elsewhere that a 430W should work fine for this card.
Is it likely that the card is dead? Or do I have some kind of compatability/power issue.
Any input would be much appreciated.
(Recommendations on what graphics card would be a good alternative based on my system would be much appreciated aswell. I don't have much money and pretty much all I require is that it will play xcom 2 when it comes out)
Thanks in advance :)
Have you ever had a discrete card in that board before, to know for sure the slot is working?
Nope, I got the motherboard a few months ago, have been using integrated graphics since then and now this is the first time I've tried using the pci-e slot.
Is that a common fault?
Naw, not really. Forget I even mentioned it. The card is the likely problem.
