I have a 22 inch Sceptre x22wg (1680x1050) monitor. Originally connected by a DVI to HDMI cable, and now connected by a DVI to DVI cable. Hooked up to an Nvidia 275 gtx. I have owned the monitor for about 4 to 5 years.
Current Problem:
Description of problem is while the computer is powered on.
When I turn on the monitor the blue power LED blinks slowly. About a 3 second pause in between blinks. While the power LED blinks there is nothing being displayed on the screen. No computer output, no black background with text stating "no signal" or anything. During the blinking of the LED I can hear something inside the monitor. The only way I can describe it is a clicking sound. It's audible to the point that I can hear it from my chair about two feet away. I let the monitor do this for a few minutes and then the display itself will start. A black background with text displaying "no signal". I then wait another few minutes and finally the video output from the computer will show up on the screen.
Any ideas what could have caused this, and if this is a sign that the monitor is about to fail?
Earlier Symptoms:
A couple of days ago the monitor would not display any computer output but the "no signal" text was displayed. I fixed this by rebooting the computer a couple of times.
It happened again but a reboot didn't solve the issue so I swapped cables from a DVI to HDMI to a DVI to DVI. Same thing happened a day later but I was able to resolve the situation but unplugging the DVI port on the monitor and plugging it back in while the computer was on.
This morning I turned the monitor on and not only was there no video being displayed but the power LED did not come on. It seemed as if the monitor was receiving no power at all. I listened closely (ear right over the grill on top of the monitor) to the inside of the monitor and could hear a faint clicking. I'd say the click had about a 2 to 3 second pause to it. I unplugged the power cord to the monitor and plugged it back in. Nothing.
I decided to power cycle the device a few times waiting roughly 10 to 20 minutes between unplugging and plugging back in. Eventually I got the power LED to come on again. At this point I just let the monitor sit there and after waiting it started acting like I described under "Current Problem"
Thanks for any help or comparable past experience you can share.
Current Problem:
Earlier Symptoms:
